How the heck to change Glovebox light bulb
Old Feb 7, 2026 | 03:53 PM
cybercop's Avatar
Default How the heck to change Glovebox light bulb
OK, somewhat ashamed to ask something that should be soo simple, but this is kicking my ****.
How do you get the bulb out? I can't even figure out how to get push button assembly out.
Old Feb 9, 2026 | 10:44 PM
wichipong's Avatar
if i remember correctly i had to drop the lower glove box like accessing the CJB to replace that bulb.. but its been a while since i did it and really do not open it that much so mine might be out now.. haha
Old Feb 10, 2026 | 06:50 PM
cybercop's Avatar
Thanks, It is already out because I was messing with the CJB. I think it has something to do with the white ring around the plunger button, but can't figure out what.
Old Feb 12, 2026 | 05:51 PM
cybercop's Avatar
OK, figured it out. you need to remove the three screws at top of the lower glove box that holds the dash together, using a small screw drive pull the white ring (clip) around the plunger/switch towards you and then push the whole switch mechanism out but pulling down on the part you took the three screws out of.
Looks like a 168 bulb.
Old Feb 13, 2026 | 04:05 PM
cybercop's Avatar
BTW, those three screws I was talking about where not actually there, son might have removed them. Does anyone know what kind and size they are?
darrang1
Feb 10, 2013 11:46 AM
luxury1
Feb 28, 2009 01:10 PM
WolfPack
Nov 7, 2008 01:41 AM
Claree
Freelander
Nov 8, 2005 11:12 PM
AzCamel
Jun 14, 2005 08:39 PM
