How the heck to change Glovebox light bulb
OK, somewhat ashamed to ask something that should be soo simple, but this is kicking my ****.
How do you get the bulb out? I can't even figure out how to get push button assembly out.
if i remember correctly i had to drop the lower glove box like accessing the CJB to replace that bulb.. but its been a while since i did it and really do not open it that much so mine might be out now.. haha
OK, figured it out. you need to remove the three screws at top of the lower glove box that holds the dash together, using a small screw drive pull the white ring (clip) around the plunger/switch towards you and then push the whole switch mechanism out but pulling down on the part you took the three screws out of.
Looks like a 168 bulb.
