Increased fuel consumption, moved to CA
Old Jun 13, 2015 | 06:15 PM
fromthebackrow's Avatar
Default Increased fuel consumption, moved to CA
We moved our LR3 from TN (where we have 93 octane fuel) to our daughter in CA (where the best you can get is 91). She's reporting about 1-2 mpg less in mixed driving. Thinking it's the funky CA fuel with all of the additives they use during the summer and the lower octane rating, Yet another reason to avoid the place. Comments (on the fuel consumption issue) welcome.
Old Jun 13, 2015 | 07:09 PM
jafir's Avatar
Maximum and minimum octane available in your area usually has to do with elevation. Higher elevations have thinner air and this can allow the use of lower octane fuels. (Essentially lowers the compression). Thinner air and lower compression will also reduce power and fuel economy.
Old Jun 16, 2015 | 08:23 AM
Ghaniba's Avatar
What is the terrain difference between the two locals? I know where I live I've got a lot of hills that folks don't, but many less stoplights than others. 1-2mpg difference would be a pretty easy thing to overcome with just pedal use too. Did she drive it back in TN full time too? Could simply come down to driver difference as well.
Dave
Old Jun 16, 2015 | 08:30 AM
Jagfixer's Avatar
Maybe differences in traffic.
Old Jun 16, 2015 | 09:16 AM
DavC's Avatar
I'd be interested in this phenomenon exactly, will be moving back to CA in two months after living on the east coast for a few years. Can confirm, traffic is absolute garbage around LA or the SF bay area, so I could easily imagine this could contribute to horrible fuel economy. At least we don't have as many hills
Old Jun 21, 2015 | 05:07 PM
Thanks everybody for the feedback. We think it is the different fuel octane rating (again CA has 91 octane with it's special "smog" blend) and we run 93 octane here in TN. Higher octane rating, more energy per LB of burnt fuel. Also difference in traffic between So Cal and the "country" outside Nashville. The LR 3 checks out OK otherwise.
Spencerfitch
Dec 20, 2014 04:56 PM
Hebe33
Jun 11, 2007 03:12 AM
Andre David
Sep 20, 2006 10:36 AM
dkirchner
Aug 14, 2005 11:19 AM
discoverytimcf
Feb 10, 2005 05:17 AM
