Inside rear row door pull inoperable
Old 10-06-2016 | 11:03 AM
ljdiscovery's Avatar
Default Inside rear row door pull inoperable
The inside door handle on the rear driver's side door doesn't seem to be connected to anything. You can pull it, but nothing happens, it seems to be free and smooth. In addition, the door will not lock, using either the fob or the manual latch on the door itself. The alarm does work. If you open the door with the alarm set, it screams like crazy, thankfully. Before replace the lock/latch assembly, any ideas? thanks Phil
2005 LR3 HSE, HD Tonga Green/tan Interior
2006 Range Rover Sport HSE Giverney Green, Alpaca Interior
Old 10-06-2016 | 12:05 PM
cmb6s's Avatar
Make sure the child lock isn't on? Wouldn't affect the ability of the door to lock/unlock, but would make the interior handle inoperable.
Old 10-06-2016 | 12:24 PM
houm_wa's Avatar
Good call, cmb6s!
Old 10-06-2016 | 02:21 PM
I will check that out. thank Phil
Old 10-06-2016 | 03:24 PM
That would have been too easy. It was not the child lock. Phil
Old 10-06-2016 | 04:16 PM
cmb6s's Avatar
Oh well, it was worth a shot. The cable actually snapped on my wife's RR and I had to take the door card off and replace the cable. You might find the same thing. Cables are much cheaper than the mechanism itself, so I would tear it apart first to make sure you know what you need before ordering anything.
Old 10-10-2016 | 01:50 PM
bbyer's Avatar
Default cycle the locking system a few times and ....
I would play with the child lock and generally cycle the locks a few times while playing with the inside latches etc.
For some reason, the bits within the door can get out of syn - probably lack of use, and if you are luck, playing with the latches and opening and closing the door can get the bit to align again.
I would try this as if you pull the door card off, (not easy),, for the most part, probably nothing will appear broken, (that would be too easy), so one would be still looking as to how to align the bits - fiddly finger stuff.
I have read posts where it appears that children playing with the latches etc and have found some way of disabling all. Interrogation of the felons as to what they did has only yielded tears - that of the parents.
brad_ramsey
04-27-2016 11:57 AM
Bishop
05-31-2013 10:39 PM
raj49
01-06-2009 07:27 PM
msl64
11-20-2008 08:56 PM
wick_60010
04-18-2008 11:24 PM
