Inside rear row door pull inoperable
Old Oct 6, 2016 | 10:03 AM
ljdiscovery's Avatar
Default Inside rear row door pull inoperable
The inside door handle on the rear driver's side door doesn't seem to be connected to anything. You can pull it, but nothing happens, it seems to be free and smooth. In addition, the door will not lock, using either the fob or the manual latch on the door itself. The alarm does work. If you open the door with the alarm set, it screams like crazy, thankfully. Before replace the lock/latch assembly, any ideas? thanks Phil
2005 LR3 HSE, HD Tonga Green/tan Interior
2006 Range Rover Sport HSE Giverney Green, Alpaca Interior
Old Oct 6, 2016 | 11:05 AM
cmb6s's Avatar
Make sure the child lock isn't on? Wouldn't affect the ability of the door to lock/unlock, but would make the interior handle inoperable.
Old Oct 6, 2016 | 11:24 AM
houm_wa's Avatar
Good call, cmb6s!
Old Oct 6, 2016 | 01:21 PM
I will check that out. thank Phil
Old Oct 6, 2016 | 02:24 PM
That would have been too easy. It was not the child lock. Phil
Old Oct 6, 2016 | 03:16 PM
cmb6s's Avatar
Oh well, it was worth a shot. The cable actually snapped on my wife's RR and I had to take the door card off and replace the cable. You might find the same thing. Cables are much cheaper than the mechanism itself, so I would tear it apart first to make sure you know what you need before ordering anything.
Old Oct 10, 2016 | 12:50 PM
bbyer's Avatar
Default cycle the locking system a few times and ....
I would play with the child lock and generally cycle the locks a few times while playing with the inside latches etc.
For some reason, the bits within the door can get out of syn - probably lack of use, and if you are luck, playing with the latches and opening and closing the door can get the bit to align again.
I would try this as if you pull the door card off, (not easy),, for the most part, probably nothing will appear broken, (that would be too easy), so one would be still looking as to how to align the bits - fiddly finger stuff.
I have read posts where it appears that children playing with the latches etc and have found some way of disabling all. Interrogation of the felons as to what they did has only yielded tears - that of the parents.
brad_ramsey
Apr 27, 2016 10:57 AM
Bishop
May 31, 2013 09:39 PM
raj49
Jan 6, 2009 06:27 PM
msl64
Nov 20, 2008 07:56 PM
wick_60010
Apr 18, 2008 10:24 PM
