Intermittent passenger headlight low beam
Old Jun 15, 2016 | 12:34 PM
bhmav8r's Avatar
Default Intermittent passenger headlight low beam
Searched and read all I could . . . but
2006 LR3
Replaced the bulb, swapped everything to the drivers side - bulb, ballast, assly work on the drivers side - the drivers side stuff doesn't work on the pass side. So its behind the connection.
Checked the headlight fuses, no joy. Its beyond my skill/patience to fix. The wiring and plastic parts are still in very good shape so I'm not thinking the wiring has deteriorated.
So I took it to the inde shop (very knowledgeable). He's had it for two days and I suspect he may be stumped. I'm sure he's checked all the fuses and relays first.
Any suggestions? Thanks in advance.
Old Jun 15, 2016 | 12:43 PM
DavC's Avatar
Sounds like you answered your own question.
Best bet is to bite the bullet and describe the problem, history to a dealer tech and then ask their thoughts and proceed to have them fix it.
Just before doing that you may want to see if any fault codes are present, and check the fuses in both fuse boxes, though you may have already done so. I am not aware if drivers and passenger side are separately fused.
Old Jun 29, 2016 | 11:55 AM
bhmav8r's Avatar
My inde traced it to the fuse box under the glove box and replaced it $1400.
Is the old box worth anything? Other than the fuses and relays?
Old Jun 29, 2016 | 12:25 PM
abran's Avatar
$1400? Damn.
Old Jun 29, 2016 | 08:36 PM
EastCoast's Avatar
Originally Posted by abran
$1400? Damn.
That's what I was thinkin'
Old Jun 30, 2016 | 05:58 PM
bhmav8r's Avatar
Whats the box go for?
He also had a day looking for the problem?
Old Jun 30, 2016 | 06:28 PM
TOM R's Avatar
So what was wrong with the box? Corrosion?
Old Jul 1, 2016 | 10:15 AM
bhmav8r's Avatar
Don't exactly know.
Headlight power to the panel, no power out of the box to the headlight...
NFC
Mar 22, 2016 02:26 PM
WYRover
Oct 29, 2014 10:29 AM
tsuami1
Mar 9, 2009 07:33 PM
Chrisinhouston
Feb 25, 2009 06:15 PM
LR4LIFE
Nov 6, 2007 10:23 PM
