Intermittent Wiper Relay
Old Jan 23, 2017 | 09:36 AM
aBs0lut30's Avatar
Default Intermittent Wiper Relay
Hi guys, need some info...
I had to replace the relay on the wipers a little while ago, since then the intermittent wiper settings don't work at all.
I have wipers only if I hit the switch for the manual (mist) mode, or at full speed but nothing in the middle.
I'm assuming I ended up putting the wrong relay in, but now I cannot find out what relay is supposed to go in it.
Can anyone tell me what relay I need to put in there to get that working again?
Thanks!
Old Jan 23, 2017 | 10:33 AM
LR Techniker's Avatar
Its always best to match them up when you remove, because the parts catalog just lists them by color, number of pins and Amperage rating.
I "think" the wiper relay is YWB500030
It should be a Black 20A 5-pin relay
Also keep in mind there are TWO wiper relays, right next to each other.
bleizit
Jun 24, 2020 04:03 AM
Bartlomiej
Jul 4, 2019 10:48 AM
ge234
Jan 25, 2016 02:12 PM
RicketyTick
Jun 24, 2014 06:58 PM
s10lowrider1994
Oct 6, 2011 01:22 AM
