Key Fobs
My new to me 06 came with two keys. One starts the car but is otherwise destroyed. The other looks practically new but will not turn over the engine
For the first one, I’m guessing I can just order a new fob case and switch out the key.
For the second, is this a symptom of needing a battery or programming? I have a gap tool on the way so hopefully just programming.
Last edited by Columbiar; May 22, 2023 at 10:25 PM. Reason: Found answer to question
Likely programming. The remote button function is separate and independent of the starting function. That is a totally dead fob will still start an LR3. With that said, if it has been programmed before it may not take new programming. You may need to buy a new blank key to program, for that you need one function key which fortunately you have. Then it is just a matter of following the GAP directions.
