Key-lock solenoid circuit ?
Old Jul 15, 2016 | 01:55 PM
Roverrrgirl's Avatar
Default Key-lock solenoid circuit ?
Guys is there a solenoid to be changed in the ignition when code P173E-00 appears? the code came up during diagnostics on my LR3 and the key gets stuck after I turn off the car sometimes ...anyone???
Thanks
Old Jul 18, 2016 | 06:42 AM
anybody ??
Old Jul 18, 2016 | 07:15 AM
cmb6s's Avatar
My first guess would be that perhaps your brake light switch has gone bad. Second guess would be the shift interlock solenoid (the thing that tells the car that you are in "Park"). I would try the brake switch first because it's a known issue with our cars, is relatively cheap (FoMo part on Amazon is like $15-20), and takes about 2 mins to replace.
Old Jul 18, 2016 | 08:35 AM
Awesome...: My local Autozone sells the same part but made by Duralast ..is it good or should I purchase the FoMo brand ?
Thanks
Old Jul 18, 2016 | 10:14 AM
houm_wa's Avatar
It's $15...just get the genuine part.
Old Mar 12, 2022 | 05:08 PM
woodboat's Avatar
Did you get an answer to this question? I’m getting the same error code. How did you fix this?
Old Mar 12, 2022 | 05:15 PM
yes. Sold the car since then but it was the brake switch
Old Mar 12, 2022 | 05:28 PM
woodboat's Avatar
My ignition turns over and acts like it will start, then stalls. Also experiencing transmission shifting faults. Does this sound familiar?
Old Mar 12, 2022 | 05:34 PM
Yes if I remember correctly once I replaced the brake light switch everything was good. I would start with that..its about $15. Good luck to you.
hh65flyer
May 1, 2018 09:22 PM
gpelite
Jun 9, 2014 11:10 AM
zeroone
Feb 28, 2014 06:47 AM
A5scott
Aug 4, 2012 04:51 PM
twaszak
Jun 27, 2011 01:32 PM
