Knocking sound Rt. Rear Wheel
New SE, 43 miles purchased showroom model. First road trip. Loaded car with dog, camping gear and canoe up top. On the way, (all blacktop) start hearing a knocking at right rear wheel. Frequency mimics speed, no change with or without applying brakes, worse when loading the right suspension by turning left. No error messages, tried all 3 heights and all traction selections without change. Great. Another car chalked up to first model year! Let's hope nothing major, and no other issues soon or we'll be looking for a buyback.
MO
MO
Can you describe the knocking you hear or even post a video of it?
Based on the date of that original post, I'm not sure I'd bet that this would solve your issue. It's more likely a rear sway bar bushing. Again, need to know what you are observing.
another item to check would be your drive shaft center bearing. I just bought a very used LR3 that made similar sounds on the way home, and found the center bearing rubber is perished. The bearing is rolling freely in the steel hoop. Helluva racket rom the start and quiet as a churchmouse at speed.
