Knocking sound Rt. Rear Wheel
Old Aug 7, 2005 | 11:21 PM
mowensmd's Avatar
5th Gear
Default Knocking sound Rt. Rear Wheel
New SE, 43 miles purchased showroom model. First road trip. Loaded car with dog, camping gear and canoe up top. On the way, (all blacktop) start hearing a knocking at right rear wheel. Frequency mimics speed, no change with or without applying brakes, worse when loading the right suspension by turning left. No error messages, tried all 3 heights and all traction selections without change. Great. Another car chalked up to first model year! Let's hope nothing major, and no other issues soon or we'll be looking for a buyback.
MO
Old Aug 9, 2005 | 05:01 PM
mowensmd's Avatar
5th Gear
Default Answer:
Broken parking brake clip.
Known problem according to dealer, they have seen it before.
Old Aug 19, 2024 | 12:54 PM
mrmiller835's Avatar
8th Gear
I have this problem at low speeds, did this solve the issue?
Old Aug 19, 2024 | 03:58 PM
houm_wa's Avatar
Can you describe the knocking you hear or even post a video of it?
Based on the date of that original post, I'm not sure I'd bet that this would solve your issue. It's more likely a rear sway bar bushing. Again, need to know what you are observing.
Old Aug 20, 2024 | 11:49 AM
8th Gear
Sure thing and great idea! I will get a video and sound clip of the thud and knocking sound. To describe it a little further, it sounds and feels as if it's coming from the rear passenger side wheel. At low speeds and from stand still starts, especially during the first few minutes of driving the vehicle, it usually has a mild to moderately hard "thud" sound. (Envision slack in something that catches up and knocks/thuds.) Then there is a low knocking sound, something of a rattle, but as I've seen others describe (basketball bouncing sound). This goes until the rpm's jump and the gears switch into higher gears. Usually every time I accelerate faster the sounds will cease.
Old Aug 21, 2024 | 07:40 AM
Gnomadf's Avatar
another item to check would be your drive shaft center bearing. I just bought a very used LR3 that made similar sounds on the way home, and found the center bearing rubber is perished. The bearing is rolling freely in the steel hoop. Helluva racket rom the start and quiet as a churchmouse at speed.
Old Aug 21, 2024 | 11:07 AM
8th Gear
Thanks! I'll write that down and check it.
DaBull
Dec 10, 2024 02:17 PM
Jazzytris72
LR4
May 2, 2024 12:06 PM
Blumr2
Apr 24, 2019 05:39 PM
terryga
Jul 22, 2017 10:16 PM
fromthetips
Aug 25, 2010 11:06 AM
