Leak from behind the transfer case, proper ID.
Old Apr 20, 2016 | 10:53 PM
Zelatore's Avatar
Originally Posted by cmb6s
I dunno. The spray pattern on that grease in the first picture indicates it's across the car, left to right. If it was from the CV joint, it would be more of a front to back spray pattern. Besides, the CV boots I've had fail certainly haven't resulted in a pattern that nice... it's more like every thing is just covered is nasty grease... everywhere.
EDIT: Oh, DRIVESHAFT CV. My bad. That could certainly be a possibility.
ha....I read this thinking 'front to back? how?' Then I got to the edit.
FWIW here's a pic from when I killed the front joint on my driveshaft. Pretty similar grease pattern.
Old Apr 21, 2016 | 08:48 PM
rally1's Avatar
Yep, that seems to be the issue. Ill run it to the shop to see if warranty will cover it, from what i have read its not considered a servicable part, should be straight swap. But they denied a torn front axle cv, so I wont hold out hope. If not, back under I go!
A-will-2-live
Sep 17, 2012 01:15 PM
klaine1
Jan 6, 2010 08:22 PM
meltdowndave
Jun 22, 2008 06:25 PM
shark19
May 12, 2008 08:15 PM
dammad
Jun 17, 2007 09:14 PM
