Leaking water into drivers floor board
Its either your air conditioning tubes which are clogged, or your driver side a pillar needs to be taken off and the hole on the bottom needs to be taped over. Check your sunroof drains as well. Pour water in the front part of sunroof/driver side and water should pool out from front driver side tire. if not your sunroof drain tubes are clogged. I just dealt with this issue, but it was the passenger side on my truck.
southarm34
02-20-2011 09:12 AM
