Leaking water into drivers floor board
Old Mar 5, 2013 | 04:00 PM
LRgirlfromMS's Avatar
Default Leaking water into drivers floor board
My 2005 LR3 has started leaking water into the driver's floor board when it rains. That has caused my sensors to go crazy and my keyless remove won't work anymore. Has anyone had this problem and know how to fix it?
Old Mar 6, 2013 | 03:51 PM
mx468's Avatar
Its either your air conditioning tubes which are clogged, or your driver side a pillar needs to be taken off and the hole on the bottom needs to be taped over. Check your sunroof drains as well. Pour water in the front part of sunroof/driver side and water should pool out from front driver side tire. if not your sunroof drain tubes are clogged. I just dealt with this issue, but it was the passenger side on my truck.
MichaelDisc02
Jul 27, 2015 12:10 PM
SStrobel
Sep 28, 2012 03:24 PM
0304Disco
Apr 8, 2011 12:55 PM
southarm34
Feb 20, 2011 09:12 AM
nashville rookie
Jan 20, 2010 08:15 PM
