Driver door won't open
Old Mar 5, 2013 | 05:12 PM
Kinz384's Avatar
Default Driver door won't open
My driver door won't open. From inside or outside. It's stuck in locked position.
My remote, inside button, even manually won't unlock.
What causes this and how can I get it unstuck?
I did a search and saw the how to - to take panels off. But if its closed will I still be able to get panel off ?
Old Mar 6, 2013 | 12:35 PM
houm_wa's Avatar
You cannot manually put the latch in the "unlock" position and open the door???
Old Mar 6, 2013 | 07:35 PM
Kinz384's Avatar
Nope.
Old Mar 7, 2013 | 07:00 AM
gprtech's Avatar
If that's the case, you'll have to pull the door panel and operate the latch manually.
Old Mar 7, 2013 | 08:20 AM
The door has a lock motor and a super lock motor. One potential problem is that superlock is engaged (can't open inside or out), and the cable that drives it is has now become open (door flex cable broken internally). It can't get the signal to unlock. And even if you get to the cable (wire colors black/purple and black/green) inside the truck putting 12 volts on it may not help as you will be on the other side of the break.
If an owner wanted to disable the superlock function, they could snip the black purple wire at the central junction box. As long as doors are not superlocked to begin with.
Attached wiring diagrams and shop pages on the door panel and latch removal. Might cause discouraging words to be heard.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 7, 2013 | 09:02 AM
Kinz384's Avatar
So if I cut the wires. My door will open ?
Old Mar 7, 2013 | 09:39 AM
gprtech's Avatar
No. You will need to move the mechanism by hand.
If this is the cause, cutting the wires will prevent it from doing it again.
Old Mar 7, 2013 | 09:46 AM
Important point for those new to the door locks, they are called lock motors for a reason, they actually are a small DC motor. Power is applied in one direction to lock, and reversed to make motor move in the other direction to unlock. Superlock is a second lock motor that over rides all physical latches. So they can bash the glass and still snag the laptop, just won't be able to get the new BBQ grille out the window.
Old Mar 7, 2013 | 10:40 AM
houm_wa's Avatar
I didn't think that the so-called "Super Lock" feature actually did anything, on my '05 at least. I remember reading about it in the manual, trying it...and thinking it simply was not installed and possibly just left in the literature after being copy/pasted from the RR manual.
Old Mar 8, 2013 | 06:43 PM
Kinz384's Avatar
If i just get panel mostly off & disconnect the Door latch remote release cable, will i at least be able to open my door and be able to use it. Til I can get it to shop to get it fixed ?
joshp01
Dec 5, 2021 07:50 PM
SuperSport
Jul 23, 2014 01:04 PM
toofaroffroad
Dec 22, 2013 12:17 AM
nycranger
May 5, 2013 05:23 AM
darren24
Aug 6, 2012 05:21 AM
