Left front airbag
Old Apr 8, 2024 | 12:28 PM
Jim20's Avatar
7th Gear
Default Left front airbag
LR3 2005
I'm looking for a little help. I have replaced the compressor and both leveling sensor. I still get a active. fault code and when I try to raise it to go off-road. The left side does not come up.
Old Apr 8, 2024 | 01:10 PM
houm_wa's Avatar
What is the fault code?
Old Apr 8, 2024 | 01:32 PM
Jim20's Avatar
7th Gear
System fault special programs.
Old Apr 8, 2024 | 01:35 PM
Jim20's Avatar
7th Gear
The first code that comes on suspension fault, normal height only.
Old Apr 8, 2024 | 01:42 PM
Jim20's Avatar
7th Gear
About 4 months ago I replaced the valve block. Just pass the right front tire. Just about 2 weeks ago, my air compressor went out and I
replaced it with the wheel sensors..
Old Apr 8, 2024 | 05:55 PM
DakotaTravler's Avatar
Did you have this issue before doing any work?
Old Apr 9, 2024 | 05:25 AM
Jim20's Avatar
7th Gear
Default Airbag
Yes I did
Old Apr 9, 2024 | 07:10 AM
Rufflyer's Avatar
After replacing the leveling sensors, Did you calibrate the suspension?
Jeff
Old Apr 9, 2024 | 07:16 AM
Jim20's Avatar
7th Gear
I did not....
Jimbo4864
Range Rover L322 (3rd Gen)
Aug 30, 2023 12:53 AM
Rustyking
Jul 19, 2023 04:40 AM
KyleP
Jan 11, 2021 06:08 AM
Altitudes
Apr 15, 2019 08:38 AM
wichipong
Oct 26, 2018 11:19 AM
