Lot's of Error codes --06 LR3
Old Jul 25, 2019 | 07:43 PM
Scott_C's Avatar
Default Lot's of Error codes --06 LR3
Hello all
I have had my LR3 for 7 months now and love it.
It is pretty much stock other then the previous owner put larger tires and I believe ~2 inch Johnson rods on it .
From the get go it had a secondary O2 sensor code and since it was the secondary one I have not rushed to change it (I have the part)
Also , Once in a while and usually on the highway a suspension error would come up and I would get the "lowering and no special programs" message.
This does not effect it's drive-ability and it was rare so it also got put on the "ignore for now list"
I also noticed that if left sitting for a day or two the front suspension would slowly lower on the right side a lot and maybe the left side a bit..
About 1 month ago I was getting an intermittent fault and it usually came up when depressing the brake, I changed the brake switch and that seemed solve this problem.
I have also just changed the battery with a new 900 CCA (even though the cheap tester I purchased on Amazon said it was good)
Why the post
Well lately (both before and after the battery change) I am getting a hole bunch of codes (see attached iLAND report , I purchased the software) Suspension program. Transmission faults...etc Now it still drives normal.. just no special programs .. I would like the special programs back and the ability to select the height I want ( access,normal,high)
Also on the the "to do list" and since I just started a few week holidays I am about to do rear bushings,"they squeak" the above mentioned O2 sensor
I also have the parts to replace the speed sensors and the Ride Level sensors, OH and I have set of rear light bulbs (yes the proper ones)
From what I an reading on these threads/Posts, it seems like I may have wiring issue. What do you think? If that is true where do I start looking first based on the attached errors?
I am pretty handy mechanically, but I don't now a lot about these various LR systems. So help diagnosing would be appreciated.
Thank you
Scott
Old Jul 26, 2019 | 05:23 AM
Globetrotter448's Avatar
Firstly, as you put in a new battery, I would do a hard reset, that is, disconnect battery, use a screwdriver and bridge the positive and negative cables together for a couple of minutes (keep clear of shorting battery). This will clear most codes. Reconnect battery and start vehicle and see what codes appear. This may give you a better picture of what is wrong.
Old Jul 26, 2019 | 06:34 AM
Scott_C's Avatar
Hello Globetrotter448
Thanks for the response. I reset / erased all of the OLD codes several times both before and after the battery swap using to scanning/diagnostic tool, Do you think the battery method does something more/better then using the the scanner?
Scott
Old Jul 26, 2019 | 06:37 AM
Most certainly, it clears codes that some tools cannot.
kip lightning
Jun 7, 2015 04:27 PM
GWDRoverTX
Jan 16, 2013 10:22 PM
Ricki Landers
Nov 25, 2011 09:10 PM
hattoe
Sep 23, 2010 09:45 PM
03discoman
Sep 2, 2009 04:32 AM
