lower control arm bushings?
Old Sep 8, 2013 | 09:45 PM
  #41
jrrover's Avatar
Default still have the clunk
2006 lr3 w/ 110k...had left front and right front lower swing arm bushings replaced...but I still have the clunk. Any here have any ideas on what may be causing it? Thanks.
Old Sep 9, 2013 | 03:59 PM
  #42
houm_wa's Avatar
swaybar bushings?
Old Sep 10, 2013 | 04:54 PM
  #43
fromthebackrow's Avatar
Could also be tie-rod ends..(I think).
Old Sep 24, 2013 | 08:35 AM
  #44
4puf's Avatar
7th Gear
Default Bolt seized up. best way to cut them?
Originally Posted by Mack73
Make sure you order new bolts - people often need to cut them off as they are siezed up.
Oh and make sure the shop that does the alignment (suggest dealer) has the correct computer to put the vehicle into tight tolerance mode to make sure the air suspension doesn't move during the alignment
The back bolt of of the lower control arm is completely seized inside the bushing.
What is the best way to cut them?
If I saw them off from the outside of the frame support I don't believe I will be able to pull the control arm out.
I think I should be cutting between the frame and the bushing but there is not enough space.
Any suggestion?
Old Sep 24, 2013 | 12:05 PM
  #45
roverguy7's Avatar
It's not fun.
Need to cut from the inside, and through the bushing sleeve and bolt. Use care to not damage the mounting bracket.
Best way, but not real feasible outside of a shop, is plasma torch through the control arm bushing sleeve, for access to the inner sleeve, which can then be cut much easier.
Also, don't try to turn the bolt to free it up, as you will rip the bushing and have the whole sleeve loose from the arm, which makes it more difficult to cut.
Get a good sawzall, and some good blades, and remember pressure cuts, not speed.
Old Nov 12, 2013 | 02:26 PM
  #46
Purple.helos's Avatar
7th Gear
About to replace both LCAs. Does anyone have advice on OEM repalcement vs. Dorman or 'other' from Atlantic British?
Old Nov 12, 2013 | 02:43 PM
  #47
jafir's Avatar
I've got the doorman arms in mine. I ended up paying someone to swap them.
I kept the OE arms, I figure when the bushings go bad again I'll get poly bushings and a new ball joint and put them back in.
Old Nov 12, 2013 | 03:14 PM
  #48
7th Gear
Dave,
I'm about to replace both LCAs. Any advice on OE v. aftermarket? Are there any aftermarket to avoid? (1A = $159, Atlantic British OE = $299)
Old Nov 12, 2013 | 03:15 PM
  #49
7th Gear
How long have you had the Dorman's in?
Old Nov 12, 2013 | 03:17 PM
  #50
jafir's Avatar
A few months. It drives noticeably better compared to the bad bushings that where in the car when I bought.
I got them at amazon. With prime they were cheaper than at rock auto.
