I took the tumbler and stuck a pic in a hole in the bottom and messed with it and the key and all of a sudden it worked, just kept insert and work key and crap was oozing out of it as i did lube it a few days ago
So i then soaked and flushed the inside with brake clean, the tumbler never worked so smooooooth
Best we can figure is either there was a burr on the new key or some crud got in there from the keys , if it happens again i need to find someone that can get this apart to fix it internaly
My other thought is having it flipped allowed the lube into an area it could not get into normally
