LR3/4 - Clean those roof rails!
Old Aug 20, 2020 | 11:07 AM
denver6161's Avatar
4th Gear
Originally Posted by Rufflyer
I have a front runner roof rack. The rails were removed and it is open to clean every time I was the thing.
Just in the process of mounting a front runner rack and wondering if it was necessary to get ditch moulding to replace the open rail area on my LR3. Have you had any issues with leaving the rails open?
My truck had the factory roof rails and taking them off to install the Front Runner Slimline (with the mounting system...not the brackets) seems like it leaves a lot of area uncovered.
Thanks
Old Aug 21, 2020 | 06:28 AM
Rufflyer's Avatar
Thanks
I had one that did not have the rail system for the load bars. I simply cut the moulding off just in front of the first mounting hole. Not only does the rail system not prevent debris in the channel, the moulding is just as bad.
If you remove the moulding completely to cut it, clean out the sponge at the curved section at the front and remove the collected debris just above the windshield.
As for it being open, I think it is better off being sprayed down (rain & car wash) occasionally while open vs never while under the moulding.
Hope this helps
Jeff
Standard Disclaimer: I may be wrong.
Old Dec 28, 2024 | 01:04 PM
johnsonmc2000's Avatar
hi there, I’m asking myself the same question as I’m in the middle of putting the roof rack on now. Did you end up leaving it open? I had two bolts that were rusted in because of the debris under the original molding. I’m leaning towards leaving it open again.
Just in the process of mounting a front runner rack and wondering if it was necessary to get ditch moulding to replace the open rail area on my LR3. Have you had any issues with leaving the rails open?My truck had the factory roof rails and taking them off to install the Front Runner Slimline (with the mounting system...not the brackets) seems like it leaves a lot of area uncovered.
Thanks
adamsrotors
Range Rover L322 (3rd Gen)
Jun 15, 2020 05:58 PM
bmwrovers
Feb 22, 2020 08:09 AM
Husker
Dec 17, 2018 06:42 PM
Friendly4x4
Aug 17, 2018 06:37 PM
dvs_dale
Feb 16, 2010 06:50 AM
