LR3 brake switch adjustment?
Old Dec 28, 2017 | 07:43 AM
thumperer's Avatar
Default LR3 brake switch adjustment?
Hello,
Replaced the brakes booster today on my LR3 (all's well with the brakes now). But now the brake lights are constantly on.
Is there some way/procedure to adjust the brake lights switch?
Thanks,
Matt
Old Dec 28, 2017 | 08:55 AM
Gator996's Avatar
I think the adjustment needs to be made at the booster. You likely have to adjust the push rod a tad. I had this happen on a different car when I replaced the booster. It was fiddly getting it just right.
Old Dec 28, 2017 | 09:04 PM
Best4x4's Avatar
Remove the brake switch by removing the lower dash panel, then twist the brake switch and it should come out. Pull the actuator out, then re-insert it making sure the brake pedal doesn't move. It should re-adjust and then test your brake lights.
Old Dec 30, 2017 | 10:27 AM
thumperer's Avatar
That sounds familiar. Is it the same procedure as the Discovery 2?
Old Dec 31, 2017 | 07:54 AM
Best4x4's Avatar
On a D2 with the newer style brake switch yes
Old Mar 7, 2023 | 02:02 PM
Abdul Wajid's Avatar
4th Gear
Land Rover 3 ambigos solved 100% with proof)
Below the front right foot mate lots of cables are going backwards from the firewall , wity in these cable is a connection with splicers which is broken or rusted that causes initially intermittent and later on permanent break fault ( 3 amigos hdc , suspension , and special program off faults)
here is a link which is not very clear but enough to work on !!
djkronik57
Aug 14, 2017 02:05 PM
s10lowrider1994
Oct 22, 2014 08:58 AM
meltdowndave
Mar 17, 2012 09:08 PM
shawn
Sep 23, 2007 06:46 PM
psg
Oct 2, 2005 02:07 PM
