LR3 firewall access, found another opening!
I've put more thought into this for my setup and my plan is to use two 0awg cables, just not all the way. I am going to run just the positive through the firewall as planned. It will drop down the sill and up behind the driver seat. Under the seat I will also create a very nice ground point with special contact grease I have to prevent corrosion and enhance the connection (its used in telco applications). I may even weld the contact point to ensure the best ground possible. That puts the ground point pretty close to the aux battery ground instead of a full chassis run. From here I will put a high-amp connector where the two 0awg cables will continue on to the accessories in the rear. I thought of putting the inverter on the floor under the seat but I am not too keen on low laying electronics.
clint70
05-27-2015 11:17 AM
