LR3 firewall access, found another opening!
Old Jun 4, 2019 | 02:31 PM
abran's Avatar
True. I might need to explore that idea. Thanks
Old Jun 5, 2019 | 12:03 PM
DakotaTravler's Avatar
I've put more thought into this for my setup and my plan is to use two 0awg cables, just not all the way. I am going to run just the positive through the firewall as planned. It will drop down the sill and up behind the driver seat. Under the seat I will also create a very nice ground point with special contact grease I have to prevent corrosion and enhance the connection (its used in telco applications). I may even weld the contact point to ensure the best ground possible. That puts the ground point pretty close to the aux battery ground instead of a full chassis run. From here I will put a high-amp connector where the two 0awg cables will continue on to the accessories in the rear. I thought of putting the inverter on the floor under the seat but I am not too keen on low laying electronics.
Old Jun 5, 2019 | 12:07 PM
abran's Avatar
Cool. I’ll wait for you to pioneer it!
just post up a complete parts list, pricing, and your phone number for tech support! Jk
Old Jun 5, 2019 | 02:52 PM
thorgal's Avatar
Dakota,
on which side of the LR3 is that green arrow marked opening ? I guess chassis is universal and was meant o fit both right and left hand vehicles hence bunch of hidden openings obscured by insulation.
Old Jun 5, 2019 | 02:57 PM
@ thorgal
That is on the driver side for LHD. So the left of the vehicle. Green arrow is the opening one can sorta see around the vacuum booster looking from the engine bay, red being impossible for me to see from the engine bay.
Rufflyer
Oct 2, 2018 08:36 AM
Jeff Blake
Jun 15, 2016 07:34 AM
RawFaith
Jan 20, 2016 06:09 PM
clint70
May 27, 2015 11:17 AM
Danny Lee 97 Disco
Jul 15, 2011 09:15 AM
