LR3 front axle play at diff.......
Old Yesterday | 07:21 PM
  #51
DimaPVD's Avatar
Quick update, 32010X in National box was '''National" brand, 32010X Timken that showed up has no radius on the inner shoulder so it will not sit, didn't even try.
I got an ace up my sleeve, a very resourceful bearing place that supposed to be calling me back, they tried to reach me while I was on the road during the week and I asked to call back Monday (tomorrow)
For the other side I got 603011/049 combo and SET37, same bearings in both, one is MADE IN USA another MDA IN USA FROM US AND IMPORTED COMPONENTS, I might just use all the iffy ones to build the rusty diff and try it out while waiting for the better bearing to build a spare that has perfect gears
Old Yesterday | 07:35 PM
  #52
DakotaTravler's Avatar
You def need the prefix of XAB32010X. No way around it for the passenger side. Drive side needs the same radius of course, so double check that. If you go Timken LM603049, it will have the radius as I had no issue at all with that one. But for those brands, I would hope they are the same. To me the driver side is the most critical if you don't want to mess with shims. Passenger side can be adjusted without affecting the pinion to ring gear interface. I would look at your old bit and see how they measure up to those.
I did get the job done today. I will never do this project again without a lift, transmission stand and a second person. Period. This was one of the most hellish projects I have ever done. Overall the one unexpected hang up was that passenger side CV at the axle. But then there was the diff itself. I guess removal is not the worst one you know to remove the extension tube cause it will just Plinko® its way down to the ground. But install, which I thought would go pretty easy, was also a total pain. I did swap front driveshaft which was apparently a good idea, it was failing. I would say though that *maybe* disconnecting it from the transfer case may give you that needed extra half inch of room. But I can not say, it is so tight under there.
Side note: For anyone swapping the front drive shaft during diff swap, you need to drop the sway bar. Both sides, remove the four nuts. Let it fall and the shaft will come right out. You just need that extra little bit of room. I really wanna meet the engineering team on this truck and slap em all in the face.....
Old Yesterday | 08:15 PM
  #53
DimaPVD's Avatar
What I left out is that National brand has a required radius but I don't trust the bearing itself, was hoping to find a repackaged Timken.
Luckily I have a lift and LR tech who might be able to give me a hand.
Old Yesterday | 08:31 PM
  #54
Oh, is that the one that Rock had Timken pics under the National listing? National is a good brand, same for NTN. I would have no issue using it if it fits the needed specs. I was just paranoid cause I did not want to deal with shims.....
Lucky you! I have access to a lift and regret not using it. Even solo it would have been a lot easier on me getting this thing in and out. But I wanted to get it done over the weekend. The company I work for is what has a lift, never get used cause it was for the owner's son and his hobbies. And access to it on the weekend is a big ask cause there is a lot of other stuff in the same building.
Old Yesterday | 09:03 PM
  #55
Oh... install note that helped me get the dang thing installed. Cause of the frame component that is in the way and the diff needing to be above it for install, what finally worked was to get the diff front end (the bushing end) above its mount location and forward. Basically overshooting the front end. This game some room for it to go forward toward the steering rack and get the drive shaft lined up to couple. Then slide is down and back into place while installing at least one of the three large side bolts. Then finally getting the front bushing bolt installed. Just be careful of the rack lines that are right there. With a lift and a second person I think you will not have issues tho.
Old Today | 07:45 AM
  #56
DimaPVD's Avatar
tempted to try summit, they are reputable and specifically call if for a diff application, $53
https://www.summitracing.com/parts/tmk-32010x
also 123bearing has correct XAB23010X/Y32010X for $92
Old Today | 05:08 PM
  #57
That one from Summit, well the pics are wrong but that part number will not work. You really need that prefix of XAB. I would try a local industry supply, just make sure they know about the prefix to get the right radii on the inside. I think 123bearings is way too expensive.
DakotaTravler
Jul 4, 2025 12:00 AM
dz5bxm
Jun 10, 2015 07:02 AM
cgray11
Oct 11, 2014 06:55 AM
deer4011
Mar 27, 2012 01:01 PM
Dominic100
Nov 3, 2010 08:38 AM
