LR3 Front Crank Seal Leaking
Old Jun 28, 2019 | 10:51 AM
Tony Aguilar's Avatar
Default LR3 Front Crank Seal Leaking
Quick Question - tried searching but really found nothing...I have the manual for the LR3 and I have a suspected leaking front crank seal. The removal and replacement of the seal seams straight forward enough but I know the crank pully bolt will be just a bear as it's factory tight to 280 ft-lbs and it's been heat cycled for the last 140k
My question is (and the manual says nothing about this) what direction do I rotate the bolt to loosen it (CCW or CW - looking from the front of the engine). I want to use the starter motor to loosen the bolt and do the work for me but I'd hate to hook up the breaker bar the wrong direction and shear that bolt off or worse...has anyone removed the crank pully and could they give me any insight?
Thanks in advance.
Old Jun 28, 2019 | 02:31 PM
abran's Avatar
lefty loosey.
The Deputy
Jan 12, 2019 10:49 AM
Willie 00D2
Nov 6, 2017 03:16 AM
jamestfl
Oct 3, 2016 04:03 PM
mhunterfm
Nov 20, 2013 07:23 PM
modelwerks
Oct 3, 2005 09:29 PM
