LR3 Front Sway Bar Bushings
Old Nov 5, 2019 | 06:58 PM
nevillusa's Avatar
Default LR3 Front Sway Bar Bushings
Several mentions recently here of Front Sway Bar Bushings, so I figured I would share the photos of the tools I used, along with the old Bushings, and make/part number of new Bushings that I fitted. This all happened in February 2018.
Link to Google photos folder with photos - https://photos.app.goo.gl/1yyWdxQFzWtfJbs89
This is not a detailed 'how-to', but from memory, the following points are probably quite relevant -
1. Not a difficult job, if you have Offset Wrenches.
2. You will see an 18mm 3/8 socket with rounded off end - this was necessary to get to one of the Sway Bar Bushing Bracket Bolts on the Driver side, if I recall correctly - basically needed to make the 18mm socket 'smaller' to be able to fit into the bolt head. Something else was in the way. Carefully used a grinding wheel until I had taken off enough material for the socket to fit.
3. As always, I used plenty of penetrating lube. I probably started lubing the bolts a couple of days before the actual job. I was lucky - no stuck, rusted, busted bolts.
4. Used brand new high grade bolts, and added a little anti-seize. Not sure if the anti-seize is officially correct, but I chose to use it anyway, as future insurance against Midwest winter salt /rust.
Cheers, Simon
Old Nov 5, 2019 | 08:10 PM
abran's Avatar
Nice write up.
one thing you can do for the pain in the **** driver bolt is unbolt the diff from the bracket, then use a pry bar to move it around to get access.
Old Nov 6, 2019 | 01:28 PM
DakotaTravler's Avatar
Dont forget you had this thread Simon where I have included an image for others showing what I did to the socket.
https://landroverforums.com/forum/lr...-advice-88418/
Philip Chan
Nov 5, 2019 01:24 PM
quirozson
LR4
Apr 9, 2019 12:25 AM
pgoodrich
Feb 9, 2016 11:46 AM
ESPN
May 12, 2014 05:27 PM
timdunbar
Jan 18, 2012 11:53 AM
