LR3 fuel filler to tank house coupler
Old Dec 15, 2019 | 09:23 PM
DakotaTravler's Avatar
Default LR3 fuel filler to tank house coupler
Look like what I need is this part: LR010621 The best price I can find for this short piece of rubber is $60! If thats the only option, so be it. But I was wondering if anyone has an alternative they use or knows the exact size needed. I seem to have a very slight leak, not enough to drip. I could crank down on the clamp probably but given how old the fuel hoses are I would rather replace this small section anyway.
EDIT:
Of course after posting this I found an actual pic of the item on eBay. I will have to look again, I swore mine looked like just a piece of large fuel hose, all rubber with no obvious moulding. It clearly had a clamp on each end. So I can only think that the part pictured below attaches to the tank and there is a rubber hose that sites between this and the filler which is not pictured above or I saw things wrong.
Old Dec 17, 2019 | 11:10 AM
abran's Avatar
Its a short section of flexible hose with a clamp. Im sure you could run down to autozone etc and buy a few pieces of different sizes to try.
There is a flap in the tank, so once you remove there will be some spillage, but not a ton.
Good luck.
Old Dec 17, 2019 | 12:06 PM
houm_wa's Avatar
Default It's very fancy, though!!
What with those ribs on either side and that raised wall in the middle to separate the coupled hoses. I say get it! Hahahaha... joking. It's just rubber.
Old Dec 17, 2019 | 12:11 PM
Im beginning to think that is not the part I need. This is a pic from eBay. This is what mine looks like. I think the part I pictured above must insert into the tank and I may be correct that there is a section of hose not pictured in the diagram that connect that part to the filler pipe. I guess for now I will just tighten it up a little until I can dig into it further and get sizing. Will update when I do so others know.
Travelor
Dec 4, 2022 09:51 PM
geek_IM
Mar 31, 2018 03:03 PM
photo2u
Oct 13, 2014 04:02 PM
gunsanroses91
Nov 23, 2013 09:29 AM
nuclearw
Oct 3, 2013 11:47 AM
