LR3 HDC fault
Old Sep 26, 2017 | 07:27 PM
Scott J's Avatar
Default LR3 HDC fault
My '06 LR3 won't start. Dash lights up like a Xmas tree, and I get a HDC system fault. I plugged in a didital diagnostic tool, and got a code U0151. I looked it up & it indicates the SRS control module. Since I can't clear the errors, I assume I have to replace the module - BUT I DON'T KNOW WHERE THE HELL IT IS!!
Can anybody help?
Old Sep 26, 2017 | 07:54 PM
SRS failure shouldn't stop it from firing up.
Are all the dash lights on and staying lit up, like this?
If so behind your battery is a little silver box called the transfer case control module that if wet or corroded will cause a nightmare of errors. I was able to clean mine with contact cleaner and a toothbrush. Than filled it with dielectric grease.
Attached Thumbnails LR3 HDC fault-36387177492_3567ab4617_z-1-.jpg   LR3 HDC fault-36387177492_3567ab4617_z-1-.jpg
Old Sep 26, 2017 | 11:43 PM
Scott J's Avatar
Yes - that's exactly what the dash looks like. I was going by the diagnostic code, which indicated the SRS control module lost communication. I'll give it a shot tomorrow. Thanks for responding.
Old Sep 28, 2017 | 08:24 PM
TOM R's Avatar
Check battety grounds and load test battery
06Range
May 8, 2013 09:01 PM
mrb06lr3hse
Aug 18, 2012 10:26 AM
