Lr3 instrument cluster issues
Old Dec 11, 2015 | 03:37 PM
Smhube00's Avatar
Default Lr3 instrument cluster issues
Hi all
I have 2009 lr3 hse
Have 80k miles
Last week equipment cluster start acting up
Start getting alarms such as HDC is not available , parking beak errors , tire pressure monitoring system not working ect
It will drive fine until I stop and turn the engine off. It will not start for while.
I took it to the dealer. They are telling me that I have bad instrument cluster
It is going to cost me $1500 to replace it.
Does anybody had similar issues ?
Is there way to fix what is broken on the equipment cluster vs replace the whole thing
Any advise will be appreciated.
Thanks in advance
Old Dec 11, 2015 | 04:51 PM
houm_wa's Avatar
Check the battery first!!!
Old Dec 11, 2015 | 05:05 PM
Smhube00's Avatar
Checked the battery. It is good
Old Dec 11, 2015 | 05:19 PM
TOM R's Avatar
Is the passenger Floor wet underneigth the padding
Old Dec 11, 2015 | 05:32 PM
KMET's Avatar
Have not heard of cluster failures... Could it be that brake light switch above pedals?
Old Dec 11, 2015 | 05:40 PM
Smhube00's Avatar
Passenger floor is not wet
I change the break light switch just in case, no change
Old Dec 11, 2015 | 05:52 PM
KMET's Avatar
Have you tried cycling through gears before trying to start it?
I see you had the CATS replaced recently... Anyone know what parts are removed to change CATS?
Old Dec 11, 2015 | 06:31 PM
Smhube00's Avatar
I will try cycling the gears when I get home
Dealer did the cat change under 80k warranty
Old Dec 11, 2015 | 08:25 PM
abran's Avatar
I have a customer that has the same problem.
They bought the cluster from the dealer for $1400, and are having me do the software download and resync.
If it is your cluster, $1500 installed is not that bad.
Old Dec 14, 2015 | 06:21 AM
Smhube00's Avatar
Have you already done this work ? Just wondering whether that fix the problem?
Dealer is telling me that the material cost is $947.
