LR3 Key
Old Jul 15, 2012 | 08:04 PM
Bell05lr3's Avatar
Default LR3 Key
My keys function perfectly fine, but aesthetically they are not pleasing at all. My question is can the electronics be transferred into another case. My buttons are disintegrating, and I have been using a built up electrical tape solution. Thanks for the help.
Also, sometimes I have a strange noise coming from the front of the truck around 55 mph. It sounds like wind squeezing through some place. The a pillar trim seems fine.
Old Jul 18, 2012 | 01:07 PM
hell pie's Avatar
Yes, the electronics and key shank can most certainly be moved to another case. The hardest part of the whole transplant would be opening the old key fob. They sell new empty key fobs on ebay for relatively cheap, though I cannot vouch for the quality.
Regarding the front end noise, as you have pointed out, the A pillar trim seems to be the common culprit. I have read that the plastic tabs that hold it secure are prone to breaking.
Old Jul 18, 2012 | 04:58 PM
unseenone's Avatar
Where are you sourcing acceptable blank cases?
Old Jul 19, 2012 | 02:08 PM
bamaboy473's Avatar
remotesinc@gmail.com sells them on eBay for $139.97 including shipping. They look exactly like LR fobs...and they might be OEM, not sure.
What I learned is that dealers canNOT cut the blank key, so I guess you want to ask your dealer or a locksmith whether they can exchange the cut key into the new case.
Programming the new case is about $175 at a dealer. Remotes, INC says that locksmiths can do it, but I didn't find anybody in lower Alabama that does it.
Old Jul 19, 2012 | 04:37 PM
hell pie's Avatar
The remote cases I have seen on ebay (search "LR3 key") were selling for as low as $12. I believe they come with an uncut key shank, but no electronics. The actual electronics are just a small circuit board with the buttons and battery soldered on. The circuit board easily comes out of the case, as does the key shank.
Old Aug 13, 2012 | 09:21 AM
PalmettoRover's Avatar
6th Gear
Very good info- thanks! Been wanting to change mine for a while.
nh9095
Jan 14, 2019 12:36 AM
freelander2002
Oct 27, 2009 05:07 PM
pilsner
Apr 7, 2008 03:24 PM
plastique999
Jan 22, 2008 01:34 AM
Jay
Apr 27, 2005 03:49 PM
