Lr3 radiator fan always loud.
Old Jan 5, 2019 | 02:28 PM
Francisco M-Torres's Avatar
Default Lr3 radiator fan always loud.
Hey guys. So I’ve been having an issue with the viscous fan not slowing down after warming up. I just changed out the fan itself and it is still doing the same thing. Temp is fine. Needle stays around halfway. Any suggestions?
Old Jan 5, 2019 | 04:05 PM
A failing alternator can cause that phenomenon.
Old Jan 5, 2019 | 09:58 PM
thorgal's Avatar
Or just a relay in engine bay. That was a problem in my case.
Old Jan 6, 2019 | 02:24 PM
I probably should’ve started there before changing out the fan haha. I’ll check that later today and update.. thanks!
Old Jan 31, 2019 | 08:23 PM
Checked relay. Still loud.. any other ideas?
Old Jan 31, 2019 | 09:30 PM
what are the actual temps of the engine when running?
Old Feb 3, 2019 | 01:14 PM
Rufflyer's Avatar
I am with Army Rover on this one. If the alternator is going out, sometimes it sends funny signals to the ECU which wrongly interprets this as a high temp signal from the coolant sensor and turns on the fan.
Been there twice.
BUT it costs nothing to check relays and connections (and grounds), maybe even be liberal with the dielectric grease when you do, so try that first.
Let us know how it turns out for you.
Jeff
Old Feb 5, 2019 | 07:31 PM
hell pie's Avatar
I've noticed this happen on my vehicle when the cooling system has a leak.
cfz2882
Feb 12, 2019 09:29 PM
Davis31052
Aug 7, 2018 09:50 AM
Bravhefen
Jan 25, 2015 06:05 PM
MoShadeTree
Jan 2, 2012 09:56 PM
Eak69
Apr 6, 2010 04:50 PM
