LR3 random cruise control not permitted
Old Jun 30, 2016 | 10:12 AM
innovativems's Avatar
Default LR3 random cruise control not permitted
Morning everyone!
After reading multiple threads on this fault of "cruise control not permitted" i'm stuck. In the past 1200 miles i have had this fault happened twice and can't recreate it. Once it sets overnight, then it works fine the next day.
When i was getting alignment, the Land Rover dealer said I have all software updates.
The first time, I had one brake light out. I have replaced the tail lite/brake bulbs and also the break switch.
The gear indicator is working spot on, as is all steering wheels controls.
The next item on the list I believe is the rotary coupler but wasn't sure if there is some more troubleshooting i can do before swapping that.
Thanks!
Old Jun 30, 2016 | 01:59 PM
houm_wa's Avatar
Clockspring...
Old Jun 30, 2016 | 10:24 PM
Originally Posted by houm_wa
Clockspring...
that was the next component i was thinking. If there a way to test it or is it just bit the bullet and swap it
Old Jul 1, 2016 | 02:56 PM
houm_wa's Avatar
If I knew I'd tell ya....but since it's a mechanical part I doubt there is a way to test it.
Old Jul 1, 2016 | 03:14 PM
Niver39's Avatar
I have the same problem, how difficult is it to change the clockspring?
Old Jul 1, 2016 | 03:47 PM
doesn't look to bad other then removing the steering wheel. which isn't too bad. Just have to be careful with the air bad and following the process to disconnect properly.
Evan5291
Nov 21, 2017 07:59 AM
Manicoti
Jan 15, 2014 07:19 PM
adam123
Apr 5, 2011 09:11 AM
ktm_525
May 3, 2010 09:59 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
