LR3 rear driveshaft
Old Oct 6, 2019 | 07:43 PM
DakotaTravler's Avatar
Default LR3 rear driveshaft
Doing an inspection today and I found my center support is shot, the typical rubber failure. No symptoms so I was surprised.
Questions for those that have serviced the rear shaft. How reliable are the CV and u-joints on these things? I can go new but I am considering picking up a used, installing a new center bearing, then swapping with mine. But if the u-joints and CVs are prone to failure I may as well go new.
Old Oct 6, 2019 | 08:44 PM
I just swapped in a new shaft and moved on. Figured at 150k I was better off with new.
Old Oct 10, 2019 | 12:09 PM
abran's Avatar
Front CV joint actually fails more than the center support. We just install new GKN and move on as Armyrover says.
Old Oct 10, 2019 | 12:18 PM
Yeah, after some thought that is now my plan. Then it’s less things to worry about. Will shop around tonight.
Old Oct 10, 2019 | 01:05 PM
MIKE@LK8PARTS's Avatar
Former Sponsor
We have this here in stock https://www.lucky8llc.com/collection...hardy-spicer-1
Old Oct 10, 2019 | 01:12 PM
Running that very same rear shaft 20k happy miles
Old Oct 10, 2019 | 05:50 PM
What brand? The link URL implies Hardy Spicer which is GKN which is in turn OEM. So that would be fine. But BritPart I will not buy, already found one thread about how the BritPart rear shafts have some quality issues. So I am only looking to get GKN/Spicer shafts.
Old Oct 10, 2019 | 07:26 PM
My shaft is a gkn that was in a Brit part box
Old Oct 11, 2019 | 07:37 AM
Former Sponsor
Here is the link for the OEM rear shaft https://www.ebay.com/itm/Land-Rover-...ss!14032!US!-1
The other one I listed is Brit Part which we have had no issues with
Old Oct 14, 2019 | 04:36 PM
abran's Avatar
It seems Britpart sells 2 different quality shafts.
