LR3 Remotes
Old Apr 7, 2017 | 09:11 PM
GBR.R's Avatar
Default LR3 Remotes
if the Battery is low from lack of use in the door remote of the LR3 is it possible to bring it back to power or is it Dead and the only thing to do is replace it?
Old Apr 8, 2017 | 09:25 AM
clarkritchie's Avatar
Doesn't it charge when in use? Or does yours just not hold a charge anymore?
Old Apr 8, 2017 | 09:53 AM
GBR.R's Avatar
Not Quiet sure Yet, How long do you think a flat Remote will take to Charge up? Would it take a few days of use?
Old Apr 8, 2017 | 12:34 PM
Sorry, I've got no idea... I've got two remotes, original I think, and neither went flat after 3.5 months idle last summer...
Old Apr 8, 2017 | 01:17 PM
MacGuruTX's Avatar
5th Gear
Mine both completely died. I gave up and replaced one of them with an aftermarket shell. had to take the original key apart and then move the transmitter over, since the LR replacements are several hundred dollars.
My second one just won't hold a charge anymore, even after charging for hours...
Old Apr 8, 2017 | 05:17 PM
GBR.R's Avatar
Going to try using the Key that's not charged for a week and see if it comes back to life.
Old Apr 12, 2017 | 09:21 PM
GBR.R's Avatar
so have used the key for 5 days and dead as a door nail! O well worth a try. Note to others rotate your keys.
Old Apr 19, 2017 | 11:57 AM
Tony Aguilar's Avatar
You can replace the batteries for these - I can't recall what the actual battery is but you just have to buy the rechargable one - If memory servers and its been a while I think the best option was to just replace the casing at the same time as I think you have to cut the casing to get to the battery but it should solve your dead battery issue and save that second remote.
Old Apr 19, 2017 | 12:42 PM
houm_wa's Avatar
This is a good idea. I have a dead FOB as well. I have been resistant to cut it open for fear that I can't get it back together, but if I can get a spare case maybe it's worth "operating" on. Where is the best place to source the covers and are they OE?
93Miata
Feb 12, 2018 03:23 PM
ColoDisco
Jun 29, 2010 02:56 PM
ColoDisco
Jun 15, 2010 02:51 PM
DoverRover
Feb 20, 2006 01:05 AM
hoberock
Apr 1, 2005 02:01 PM
