LR3 Remotes
Mine both completely died. I gave up and replaced one of them with an aftermarket shell. had to take the original key apart and then move the transmitter over, since the LR replacements are several hundred dollars.
My second one just won't hold a charge anymore, even after charging for hours...
You can replace the batteries for these - I can't recall what the actual battery is but you just have to buy the rechargable one - If memory servers and its been a while I think the best option was to just replace the casing at the same time as I think you have to cut the casing to get to the battery but it should solve your dead battery issue and save that second remote.
