LR3 replacement engine cover fasteners
Old Jan 11, 2025 | 06:21 PM
muddery's Avatar
4wd High
Default LR3 replacement engine cover fasteners
I know the LR3 engine cover bolts are land rover part number LZM500020 but does anyone have any idea what the part number is for the wing nuts that the bolts secure to? Mine are all worn out.
Also does anyone know the part number for the nut that holds the bracket to the manifold for the engine cover. I was replacing my fuel injectors and lost one of the nuts into no man’s land. I think it might be a 10mm nut. There are two brackets that bolt to the manifold and the bolt that secures the plastic engine cover goes into those brackets. I lost one of the two nuts that secure each bracket.
TIA
Old Jan 11, 2025 | 07:16 PM
kajtzu's Avatar
I think you mean 1358613 (first question) and FN105042 (second question), see https://lrcat.com/#!/12128/41216/41217/3214/41639
Old Jan 11, 2025 | 07:20 PM
DakotaTravler's Avatar
Wing nuts? It is just a "j-clip", used all over and common. You could probably go to a hardware store and find what you need just by brining one of those screws with you and sizing one up. Unless I am not understanding the part you need, here ya go:
https://rimmerbros.com/Item--i-13586...C011JqOF1NVru2
The nut it also a pretty standard hardware item you can get anywhere, just bring one in to match and you will be fine. But the part number is: FN105042
Old Jan 11, 2025 | 07:21 PM
Ope! kajtzu beat me to it. <thumbs up>
Old Jan 12, 2025 | 12:28 PM
muddery's Avatar
4wd High
yes thanks I was looking for the part numbers and had trouble finding them. The bolts for the engine cover that click in are dealer only items according to Atlantic British. Local hardware stores don’t usually have fine thread nuts and bolts if they are 10mm or smaller.
LR2.bc.ca
Jan 13, 2024 11:31 PM
Rufflyer
May 14, 2021 06:04 AM
bmeier
Apr 16, 2021 06:18 PM
DaveWinCO
Nov 10, 2014 08:52 AM
RoverRu
Jan 13, 2011 05:48 PM
