LR3 stalls and steering wheel locks while driving - key issue?
Old Jul 5, 2019 | 02:16 PM
  #21
Husker's Avatar
I picked it up from the shop today. They decided it was a key issue but I have low confidence in what the decided. I think they just decided not to screw with it and held it a few days. $180. Should I keep looking for a mechanic? I might try disabling the subs and amp just to see if that helps any. Got nothing to lose
Old Jul 5, 2019 | 03:09 PM
  #22
abran's Avatar
I had a broken temp sensor wire on the coolant crossover/thermostat housing shut a vehicle down, no start, etc.
You should go through and inspect every connection including the ground cable on the battery where it connects behind the fuse box.
Old Jul 8, 2019 | 04:31 PM
  #23
Husker's Avatar
So I paid another shop $200 who came up with nothing last week. But I did unplug her subwoofers and amp, and so far, it hasn't died. I think I may be onto something.
Old Jul 9, 2019 | 01:37 PM
  #24
houm_wa's Avatar
....or maybe not. Hard to prove the negative.
You needed to be able to repeatedly produce it before, in order to diagnose and then determine if it's fixed now. I hope you are right, but mostly I just hope the symptom was erroneously reported, because a sub-woofer killing power to the entire vehicle would be disconcerting to say the least.
Old Jul 9, 2019 | 04:16 PM
  #25
Depends if it’s factory or a badly installed aftermarket set up
Old Jul 9, 2019 | 05:45 PM
  #26
houm_wa's Avatar
Please elaborate....what can the sub take out, electrically, that would cause the engine to lose power?
I've only ever heard of this happening if the Alternator goes out...and even then are signs (lights illuminating, sluggish behavior at low RPM).
Old Jul 9, 2019 | 07:17 PM
  #27
DakotaTravler's Avatar
Power drain. Basically a brown out. Sub/amp pulls so much power the alternator and battery dip low enough to shut it down. Very possible.
Old Jul 9, 2019 | 08:16 PM
  #28
Husker's Avatar
Well, looks like I missed again: She reports the car had trouble starting this afternoon. I am actually ENCOURAGED by that as it gives me some more clues. Fuel pump, ignition, ???
Old Jul 9, 2019 | 10:11 PM
  #29
houm_wa's Avatar
Default Ahhh...
...I can see that since it wipes out the alternator.
miguelalanis
Sep 19, 2019 04:42 PM
ljdiscovery
Sep 8, 2016 08:36 PM
cmshoot
May 23, 2016 09:28 AM
Jeff4190
LR4
Jan 28, 2011 12:00 AM
