LR3 Timing Set Replacement
Old Apr 8, 2025 | 01:39 PM
  #101
jessesky's Avatar
8th Gear
Default Looks like it’s in time so now what?
Hey everybody, I finally got a photo of the crankshaft position - attached. The lens was at an angle so keep that in mind but it looks pretty darn timed, no?
if so, now what? I guess the VVT sprocket? Please advise.
This is as close to straight on as I could get, does it look good?
Originally Posted by enovak
Facing the motor, it rotates clockwise. So you were turning it the wrong direction. I would try it again for a couple of revolutions and insure all good. My engine was in time, but I was getting the cold start rattle from my RH bank. My VVT sprocket was broken and not holding oil pressure.
Old Apr 8, 2025 | 01:54 PM
  #102
jessesky's Avatar
8th Gear
Default Found chain looseness
Are these chain tensioners always meant to be tensioning? Even when the vehicle has not been running for a month?
Old Apr 9, 2025 | 09:07 PM
  #103
P-Bod's Avatar
I thought that was weird at first, too, on that secondary chain. When you rotate the motor, it will tighten and loosen through the rotation, presumably due the the intake and exhaust cam lobes opposing each other. I concluded, correctly or not, that oil pressure while running maintains consistent tightness while running. Post #42..
Old Apr 15, 2025 | 01:07 PM
  #104
enovak's Avatar
Question: Our valve covers have 3 different types of bolts/grommets. In particular, each cover has 1 grommet where the bolt and the metal sleeve are separate (LR000337 = Bolt) and 4728387 is the separate metal sleeve with the rubber grommet.
Anyone know which hole in the covers take this fastener?
Old Apr 25, 2025 | 12:55 PM
  #105
enovak's Avatar
Does anyone have a strong opinion on whether we should always replace the crankbolt whenever we take it off, even if only been on for 100 miles ? I installed a new one and drove for about 100 miles and need to resolve a slight timing error so need to remove cover again to move the chain one tooth. I hate to buy another new crank bolt.
Any opinions?
Old Apr 28, 2025 | 06:37 PM
  #106
gillygong's Avatar
Originally Posted by ryansroverings
P-Bod, you are our hero for documenting this journey. Our family just picked up a second LR3, a 2007 with 160K on it and it has this condition at startup. I am going to attempt a resolution by valve cover removal and loosening the phaser housing and twisting CC and retightening to see if quiets things down. I am intrigued by that through hole that passes the cover plate and the sprocket plate and wanted to ask you if the holes are the exact same diameter for a machinists dowel pin to locate them together? It would be very interesting for scientific sake to declare that the locating holes are not perfectly in line on my phaser before I slacken the bolts. Then to use a slip fitting pin to line things up, tighten down, then report to everyone the results on a cold startup. Or maybe this track I'm thinking about isn't even important and a more simple approach of slackening the 3 torx bolts and twisting the housing CC and retightening the bolts is all that I need to try? Just want to be realistic and prepared for a successful outcome before diving in! Again thanks for doing this for the rover community!
Did you end up trying this? I haven't checked which side it's coming from yet, but I believe I have the same issue.
Vail
Jun 19, 2018 01:19 PM
jft1428
Mar 22, 2018 10:25 AM
ATXLR3
Nov 13, 2017 01:08 PM
TOM R
Nov 7, 2015 01:04 PM
fastrx7man
Jan 28, 2012 12:49 PM
