Lr3 transmission fluid
I am looking to make a more comprehensive list of trans fluids that we can use on the zf, plus i need to change ours
I dont see much information online for land rover zf, but i d8 for bmw zf, assuming its the same trans? I see that castrol transmax IMPORT multi vehicle and also valvoline max life
i also see where its recommended u drain and refill run, drain refill run, drain change the filter refill top off to be sure all the old fluid is out of the converter
I assume we need the LV 71141 spec for zf trans
thoughts on this?
thoughts on this?
