Lr3 transmission fluid
Old Jul 4, 2018 | 09:09 AM
TOM R's Avatar
Default Lr3 transmission fluid
I am looking to make a more comprehensive list of trans fluids that we can use on the zf, plus i need to change ours
I dont see much information online for land rover zf, but i d8 for bmw zf, assuming its the same trans? I see that castrol transmax IMPORT multi vehicle and also valvoline max life
i also see where its recommended u drain and refill run, drain refill run, drain change the filter refill top off to be sure all the old fluid is out of the converter
I assume we need the LV 71141 spec for zf trans
thoughts on this?
Old Jul 4, 2018 | 06:05 PM
TOM R's Avatar
The castrol trans max import muliti is out, when u read the spec sheet it says do not use where mercron sp or mercron LV is required
im gonna go with the valvoline max life multi car, specs show its good for lv 71141 and mercron LV / sp
Old Jul 5, 2018 | 04:15 AM
loanrangie's Avatar
Unless its a big cost saving i'd stick with the LG6.
Old Jul 5, 2018 | 07:25 AM
TOM R's Avatar
The valvoline is $18 a gallon at walmart think its $26 a gallon at advanced auto
Old Jul 5, 2018 | 09:33 AM
Redline also makes one that is a option for our trans doubt it's cheaper though
Quophi
Nov 5, 2009 06:19 PM
aircraftguy
Nov 21, 2008 01:00 AM
texmanmoore
Feb 23, 2008 09:18 PM
95DiscoSE7bullitt
May 31, 2007 07:40 PM
gtagg
Apr 6, 2007 09:25 PM
