LR3 transmission issue.
Old Dec 23, 2019 | 11:24 AM
Kushan Gunawardane's Avatar
Default LR3 transmission issue.
Another LR3 issue 🤦🏽‍♂️. I was driving last night and stepped on the gas to overtake but i couldn't. Rpms went up and just came back. Never downshifted. Its like it tried to shift and gave up halfway. I tried this few time and only once it worked. Has anyone had this issue? Transmission was serviced about 30k miles ago with genuine ZF fluid and filter. When cold i experience some slipping maybe 2% of the times i drive it. Its a 2005 with 140k miles. Hoping its not a big issue.
Old Dec 23, 2019 | 07:54 PM
DakotaTravler's Avatar
There should not be any slipping. First thought is that the fluid level is not correct.
Old Dec 23, 2019 | 07:56 PM
thats what i thought at first. I did look underneath and transmission area seems pretty clean. Are there common leak areas for this vehicle? I haven’t replaced the sleeve but that area seems clean as well.
Old Dec 23, 2019 | 07:58 PM
Since you are getting slipping when cold, my thought is that is was not filled correctly since the service.
Old Dec 23, 2019 | 08:00 PM
do you know if a low fluid level will affect all the gears or just a few? The downshift problem occurred when it was fully warm. Looks like I'm gonna have to do a service. Its due for one anyway
Old Jan 2, 2020 | 10:24 AM
DLLR3's Avatar
I have a very similar issue as you do. It tends to slip when it is cold. I just did a transmission service and replaced with the metal pan and filter. I did not notice any slipping prior. The slipping started about a week later. Once it warms up it seems fine.
Old Jan 2, 2020 | 11:23 AM
I would bet you didn’t get the fluid level correct after your service.
Old Jan 2, 2020 | 11:28 AM
Sounds like we both might have a low fluid level. Although in my case i cant find any leaks. I will try to dig deeper on the weekend to see if there’s anything. Im thinking in your case its a low fill.
Old Jan 3, 2020 | 01:48 PM
abran's Avatar
Im with Armyrover. I believe in both cases the fluid level was not properly filled at the time of service.
Old Jan 3, 2020 | 07:59 PM
Globetrotter448's Avatar
There is a procedure for filling the gearbox and one part requires the engine to be running whilst you add oil.
