LR4 facelift tail lights on LR3?
Land Rover Discovery 3 to Discovery 4 LED Rear Light Conversion Indicator Ballast Resistor Kit (x2)
Yes UK. Yes Expensive. Yes - look here for the info you are asking about.
is it possible to "downgrade" a newer lr4 tail lights to an older model? I found these aftermarket square tail lights I like but they're only compatible up to 2014, and I have a 2016.
thanks!
thanks!
Old thread, you would get a better response by starting a new thread. D3 and D4 rear lights should be interchangeable but you need to see the other side to see if the resistors are there and whether the matching locating pins are there
