LR4 facelift tail lights on LR3?
Old Aug 18, 2015 | 08:55 PM
  #21
TOM R's Avatar
Heavy duty
Old Aug 18, 2015 | 11:14 PM
  #22
abran's Avatar
Originally Posted by TOM R
Heavy duty
Do you know of one that will fit in the LR3?
Old Aug 19, 2015 | 07:12 AM
  #23
drowssap's Avatar
there is a uk company that sells a complete kit front and rear light and grill to convert d3-d4 crazy money thru
Old Aug 19, 2015 | 09:24 AM
  #24
abran's Avatar
Yeah, UK=$$$$$$
I checked superbrightleds.com
They have 6 ohm 50 watt resistors and 25 ohm 25 watt resistors.
Any body know which one would be best suited?
Old Aug 19, 2015 | 11:15 AM
  #25
schwaggy's Avatar
Originally Posted by abran
Yeah, UK=$$$$$$
Yes UK. Yes Expensive. Yes - look here for the info you are asking about.
Land Rover Discovery 3 to Discovery 4 LED Rear Light Conversion Indicator Ballast Resistor Kit (x2)
Old Aug 19, 2015 | 02:13 PM
  #26
abran's Avatar
Thanks! Ordering now.
Old Aug 22, 2015 | 10:34 AM
  #27
EstorilM's Avatar
I mean any $3 Radio Shack 15w resistor should work..
Got a better picture of the lights the other day.
Old Jun 9, 2020 | 07:07 PM
  #28
awesam's Avatar
6th Gear
is it possible to "downgrade" a newer lr4 tail lights to an older model? I found these aftermarket square tail lights I like but they're only compatible up to 2014, and I have a 2016.
square LR4 tail lights square LR4 tail lights
thanks!
Old Jun 10, 2020 | 02:10 AM
  #29
Globetrotter448's Avatar
Old thread, you would get a better response by starting a new thread. D3 and D4 rear lights should be interchangeable but you need to see the other side to see if the resistors are there and whether the matching locating pins are there
Old Jun 10, 2020 | 11:00 AM
  #30
houm_wa's Avatar
Are they indeed interchangeable? I thought the D4 went LED.....
