Lr4 rear locking Differential
I don't have any idea, but seeing how it's not manually engaged, I'd wonder if your ECU would even know it was there... I've read elsewhere that you can't add a factory rear locker later, that it is only available from the factory. Not sure if that's true or not...
You would think if it wasn't interchangeable, the plug or harness might be different. Maybe start there?
