Lr4 rear locking Differential
Old May 15, 2017 | 02:38 PM
Niver39's Avatar
Default Lr4 rear locking Differential
Does anyone know if a rear locking differential from a lr4 will fit in a lr3. I know the bearing kits are the same, a local rover salvage yard said that they are interchangeable but I don't think they are.
Old May 15, 2017 | 03:13 PM
clarkritchie's Avatar
I don't have any idea, but seeing how it's not manually engaged, I'd wonder if your ECU would even know it was there... I've read elsewhere that you can't add a factory rear locker later, that it is only available from the factory. Not sure if that's true or not...
Old May 15, 2017 | 05:20 PM
abran's Avatar
different part numbers, but could be a superseded number scenario, although the LR3 diff is over $1K more, so probably not.
Old May 17, 2017 | 02:56 PM
djkronik57's Avatar
Weird, wonder why the LR3 is $1k more?
You would think if it wasn't interchangeable, the plug or harness might be different. Maybe start there?
Old May 21, 2017 | 08:29 AM
AtlantaViking's Avatar
Pretty sure that they are not interchangeable. I believe that they have different axle ratios. I believe the LR3 is 3.73 while LR4 is 3.54. Be careful with RRS carriers too, the supercharged vs. non aspirated are also different ratios.
mrossipir
Jan 1, 2009 10:54 AM
workingclass
Sep 19, 2008 06:34 PM
workingclass
Sep 19, 2008 03:14 PM
gtiturbolr3
Apr 15, 2008 03:26 PM
johanba
Apr 3, 2007 11:37 AM
