Magna Transfer Case Troubleshooting
Old Nov 14, 2017 | 02:36 PM
Geo's Avatar
Geo
Loving the technical posts....very informative and the pictures help quite a bit.
Old Dec 4, 2018 | 10:49 PM
Kj_413's Avatar
Default help!
Ok, i need that same part and can't find it anywhere. Can you possibly post a link to it? Thanks!
Originally Posted by pos_lr3
Update:
Yeah, yeah... I get it... no pics, it didn't happen...
Here's the diagnosis of the solenoid's resistance...
So, it was difficult to describe how the solenoid works with just words... I said... basically, it would be two horseshoes with a groove in the middle... How about a few pictures to help?
As you can see, there is a notch in between the two forks of that clutch arm. How much force does it take to actuate the arm? Very little... the spring inside the solenoid is more than enough to counteract the default position of the forks (extended).
Here's a closer view of the T inside the forks...
So, what does the solenoid look like when it's removed?
Make note of the flexible gasket I'm holding... This part was stuck to the TB housing. While it was attached, it prevented any fluid from leaking out of the TB. Once I removed the solenoid, I lost about 3-4 oz of fluid... Here's a shot of liquid gold...
For those following along at home, TB = TC = Transfer Box = Transfer Case... Sorry, that's the UK way of looking at things.
Now, on to the update:
So, I felt I was in the best position to figure out what was going on with this solenoid... Let's see what we can sink out of the TCM...
10ma... that's all. Granted, when I hooked everything up, and tried to figure out the amp draw, I saw 1 ma when I turned the key on. Granted, this took me by surprise, until I thought about what was happening... So, basically I have a big coil (an inductor), and I have a bit of parasitic resistance from that coil (about 0.8 ohms)... So what happened? I have a series Resistor-Inductor circuit...
I recognized the exponential charge immediately, and I then waited for the final draw (source of the TCM)... 10 ma. Well, it looks like I need to update my coil prediction. I was hoping for a 1/4 - 1/8 amp draw, but it's looking like the TCM can only source 10 ma... 1200 Ohms. That's my new prediction.
We'll see what happens. I should get my new coil tomorrow. If there's something I didn't get a picture of that you'd like to see, let me know, and I'll make a picture.
Carl
Old Dec 30, 2018 | 04:49 PM
elboy0712's Avatar
Default What happened?
So what were the values on the new solenoid
Old Dec 30, 2018 | 05:29 PM
DakotaTravler's Avatar
Dontacha love when people make a post but never, every update it. Bummer! It was like a good book with the last chapter missing. pos_lr3's last login was 05-04-2018. Guess we will see if we can get an update.
Old Jun 26, 2020 | 01:07 PM
Harold Espinal's Avatar
I am having the same exact issue, can you please tell me what's the new ohm reading of the new solenoid??
elboy0712
Jun 26, 2020 02:28 PM
jjh221
Feb 11, 2017 08:58 PM
Eniam17
Mar 6, 2013 08:51 PM
far4cges
Aug 6, 2012 08:25 PM
moncton_vw
Sep 16, 2011 05:55 PM
