Multiple Error Alerts
Old May 8, 2012 | 03:22 PM
candy's Avatar
Default Multiple Error Alerts
Hi, I have an LR3 2007 MODEL. A few weeks ago I noticed that when I start my car it takes an effort for it to accelerate. The engine noise is so high and the tachometer goes as high as 6000rev/min before it picks acceleration, but at this point some warning alert noise and signs come up on the dashboard - Suspension fault, HDC Fault system unavailable, Transmission fault, Brake, DSC/ETC, ABS, Park Break and Engine fault. All these alerts are in amber colour.
I have had my injector serviced, fuel pump changed, transmission module cleaned, break switch changed all to no avail.
Pls has anyone experienced this problem and how did you resolve it. I have also attached a snap shot of my dashboard.
Old May 9, 2012 | 06:29 AM
threalassmikeg's Avatar
Sorry can't diagnose with just photos. Need to read all trouble codes in all systems
then investigate. I would recommend the dealer for this, or a Land Rover Specialist
Old May 9, 2012 | 05:48 PM
unseenone's Avatar
There are 2 scenarios that user bbyer can speak to related to your symptoms. He has had both problems, so probably can help you narrow it down more. One issue is related to a bad Viscous fan. The second issue seems related to a bad alternator. Both problems cause high idle / revving. Do not run out and buy a fan and alternator, there certainly can and are other things that could cause the symptoms, such as a shorted start cable, and so on.
If you can't diagnose this yourself, you might consider a trip to a dealer or someone who has a computer so you can plug it in and get the error codes.
The cascade of lights and errors are sometimes important, if you can pin down which lights and what order it may also help.
Old May 10, 2012 | 08:54 AM
candy's Avatar
Hi, my dealer plugged it into a computer and said no error came up. He shared the problem with hs colleagues and someone suggested it maybe the meecatronics in the gear box which explains why the computer could not read the fault and also the reason why the engine noise revs so high because the car is unable to change gear easily. Has anyone had any issues with there gear box meecatronics.
Old May 10, 2012 | 01:56 PM
unseenone's Avatar
The transmissions can fail. It seems like the dealer could / should be able to pick up an error if it is throwing up the lights.
Old May 11, 2012 | 06:34 AM
If you had all those warning lamps on there has to be codes stored!
You have more than on issue here..
First check your battery, Check AND Clean the battery terminals
Make sure the gearshift mechanism moves freely and the D is displayed
in the information center. If the D is not displayed the transmission will not
go into gear, The engine will just rev up you can also wiggle the shifter towards neutral to see If the D disappears.
If your steering wheel is that far off center while you are driving, you will need to
have the vehicle aligned steering wheel centered AND have the steering angle sensor recalibrated.
There is a possibilty the you have a transmission fluid leak and the fuid level is low
this will also cause a slipping problem in the transmission.
A Land Rover dealer would (should) have noticed the basics when you brought it in for diagnosis.
A Multi Point Inspection is performed on Every Vehicle.
You're not telling us everthing here...
jycsalas
May 22, 2015 09:05 AM
pixel
May 13, 2011 07:24 PM
nrbbnb
Jan 21, 2008 04:45 PM
enisei
May 15, 2007 02:47 PM
akartis
Oct 12, 2006 09:58 PM
