Multiple faults dico3
Old Jun 24, 2016 | 03:19 PM
Valters Zelcs's Avatar
4th Gear
Default Multiple faults dico3
Hello, greetings from Eastern Europe!
Long story short - my wife and I went to the woods today. Everything seemed to be perfect until we wanted to go back home. When i stepped in my disco3 and started the ignition, and multiple fault indicators showed up on the dashboard. :
the air suspension doesn't work. When i try to make the car higher, using the switch near gear switch, nothing happens. Also, the hi/low switch doesn't work. There is a green indicator blinking in a dashboard, which means, that the car should be in ''low'' regime, but actually, the car is in ''hi'',
Any ideas how to solve this?
Cheers!
Old Jun 24, 2016 | 09:18 PM
cmb6s's Avatar
Any chance you left the sunroof open during a rain or spilled something onto the center console (shifter) area?
Old Jun 25, 2016 | 01:01 AM
4th Gear
cmb6s, not even the smallest chance.
Old Jun 25, 2016 | 07:54 AM
TOM R's Avatar
Is the right front floor wet? Battery voltage while running
Old Jun 25, 2016 | 09:05 AM
4th Gear
The floor is dry, It's +30 degree celsius here, and we haven't seen rain for like 10 days.
The battery is 13.9 while running. :/
Old Jun 25, 2016 | 03:24 PM
DavC's Avatar
I too am thinking voltage. Do you have the ability to clear the codes and see if they come back?
only time I have had faults like that was water in fuse box and t-case box, or if it was a really cold start.
Old Jun 25, 2016 | 09:05 PM
TOM R's Avatar
Battery needs to be around 14.2/14.6 volts running
Low volts makes it run wonky
Old Jun 28, 2016 | 12:38 PM
4th Gear
Somehow the faults just disappeared. Stepped in my disco this morning, turned on the ignition, and there were no faults anymore. Weird.
Old Jun 28, 2016 | 02:40 PM
houm_wa's Avatar
Brake Switch?
Old Jun 28, 2016 | 04:30 PM
DavC's Avatar
yeah actually could totally be the brake light switch
sety
Aug 20, 2014 08:45 PM
mgabriel
Mar 30, 2011 12:31 PM
brooksa
Dec 21, 2010 06:01 PM
TYoung
Freelander
Aug 17, 2010 04:19 AM
lipadj46
Jun 12, 2009 12:04 PM
