my 05 lr3
Old Oct 27, 2014 | 08:43 PM
  #31
TOM R's Avatar
fridge out
Old Oct 27, 2014 | 08:45 PM
  #32
TOM R's Avatar
empty console
see the grey foam near the driver seat belt that the plug just ditch the foam and untape it from the harness to get slack
Old Oct 27, 2014 | 08:49 PM
  #33
TOM R's Avatar
now if you want to remove the rear panel on the console this is the time to do it since the cubby hides this screw, unscrew it and pull straight back on the rear panel it will come off
the plugs are under there for the rear heated seat buttons they are green but covered in foam
Old Oct 27, 2014 | 09:00 PM
  #34
TOM R's Avatar
installed with the coin tray installed and turned on, it takes a second or so for the switch to light up, I also think it only works with engine running gets real cold real fast few minutes maybe
Old Oct 27, 2014 | 09:07 PM
  #35
TOM R's Avatar
adding the puddle /entry lights easy but takes some time since you have to remove all 4 door panels
see the indent in bottom of panels
Old Oct 27, 2014 | 09:09 PM
  #36
TOM R's Avatar
inside there is a line molded to show where to cut
Old Oct 27, 2014 | 09:12 PM
  #37
TOM R's Avatar
cut out with dremel, don't go nuts you can always make the hole bigger
Old Oct 27, 2014 | 09:13 PM
  #38
TOM R's Avatar
here is the light
Old Oct 27, 2014 | 09:15 PM
  #39
TOM R's Avatar
plug is in that gray foam, also untape from harness
Old Oct 27, 2014 | 09:17 PM
  #40
TOM R's Avatar
installed and working actually put out a surprising amount of light at night
