My 3 blew 2 airlines and didn't fault... what?
Old Mar 5, 2018 | 08:59 AM
memphis_rover's Avatar
Default My 3 blew 2 airlines and didn't fault... what?
So over this past weekend I did my front air struts. It went pretty well the some of the old studs snapped off but that actually made it easier. I went with Arnott struts and they came with the newer style push to connect airline fittings. I followed the directions and pushed the airline in and gave it a little tug to make sure the teeth bit. Well the install went well no faults and the new springs aired right up and they drove great. Until.... I was sitting in a parking lot and I hear one loud hiss. Followed with the dread of my front left sinking. Shortly after the front right did the same. What I expected was my Christmas of lights but instead.... the truck showed it went into extended mode and said lower suspension once obstacle clear. I plugged in my IID tool.... Nothing. I re attached the airlines and went on my way and drove the truck hard the next 20 miles to see if it would do it again and it has not.
I have 2 concerns why did the truck not fault when it blew 2 lines. Faults are annoying but they serve a purpose to tell you when somethings wrong. Second why did those fittings blow when I know for certain the lines were seated. I tugged on them hard when installed and they didn't come out. I like the ease of the push to connect but it scares me if that were to happen at 65 MPH. Im going to call Arnott today.
Old Mar 5, 2018 | 09:23 AM
abran's Avatar
Not sure about why it showed extended mode, but that’s the thing about faults, only as good as the interpreter.
the push fittings are not a new style. They are the same as you removed.
I can guarantee that you didn’t push the hoses in far enough and they were holding on by a thread. There is a raised line on the tube, you need to push in as close to that line as posssible.
I have installed countless arnott bags and never had one let go.
You don’t touch the brass connectors, remove white plug, and push in tube to within 2-3mm of raised line.
save yourself an embarrassing call and go push those lines in all the way.
06Range
May 8, 2013 09:01 PM
texci77
May 26, 2012 08:33 PM
humroot
Mar 20, 2008 08:29 AM
Lar45
Jan 21, 2008 08:26 PM
